fuse box
fuse box
the small fuse holder at the bottom of the fuse box is broken. It had a wire plugged into it that looks like it was for my after market tac. one side that holds the fuse for contact is broken off. I think this fuse is for lights acc. Do I need to change the whoke box or is there a way to by pass. Where can I get a new fuse box?
M&H wiring
http://www.wiringharness.com/
Auto dash harness:
15660 DASH HARNESS, AUTO TRANS $494.00
Dash harness all with gauges:
15665 DASH HARNESS, ALL WITH GAUGES $494.00
Auto dash harness:
fuse box fix
If you want a whole fuse panel, you have to replace the entire dash harness. If you just need to replace the metal terminals, Del Mar Wire sells them.
Thank You for the info. They have what I need but I have no idea how to replace the broken one in the fuse box. It looks like some rust was the cause of the one breaking. How can I replace/ Does the whole box have to be removed? Is there somewhere I can get info on repair?
Oldscutty72
December 28th, 2015 01:56 PM
