Fuse block
Fuse block
Hope you all are having a good evening: I need help .I have a 1966 442 last saturday I noticed my courtesy lights ,clock and cigar lighter where not working. when i pulled out the 20 amp fuse (Its the bottom one on the lower right corner i broke off the rightside of the fuse holder to make things worse i lost the fuse holder clip on the broken side.I also dont see any wire. What color wire should be there. Once i find the answer to these question im thinking about using an inline fuss for the repair.any suggestions.
Thanks Tom
Thanks Tom
Your not the only one that this happens to. Here is a thread below with the same issue and solutions.
https://classicoldsmobile.com/forums...-fuse-box.html
Oldscutty72
Dec 28, 2015 01:56 PM
