Front Turn Signal issues
Old Oct 27, 2017 | 06:04 AM
drkearnel's Avatar
Post Front Turn Signal issues
Happy Friday ClassicOldsmobile!
As stated in a different thread, I just picked up a 64' F85 Cutlass and it's mostly original, so I'm dealing with a mess of electrical the past week.
I've done a lot so far, but am having an odd issue with my front turn signals. Rears work just fine after replacing the flasher, but I'm confused on how the fronts are grounded.
I pulled the bracket and can get them to work if I run a jumper to directly ground on the battery, or just place the bracket on the negative battery post. Once in the bumper, I get nothing.
Are these supposed to ground by the frame to bumper contact, or is one of the two wires within the light socket a ground that's possible bad?
Electrical is not my best area, but I feel like I'll be a pro after getting everything together
Old Oct 27, 2017 | 06:29 AM
The 2 wires on the light socket are turn signals and parking lights. It should be a 2 filament bulb, 1157. Yes they are grounded through the frame by mechanical connection.
Old Oct 27, 2017 | 06:53 AM
drkearnel's Avatar
Awesome. I'll clean up the signal housings tonight and make sure they are bolted down tight and see how that goes.
Thank you,
Dan
costpenn
Jun 24, 2015 10:38 PM
Mr Nick
May 27, 2015 11:06 AM
Freddy B
Jul 6, 2014 08:57 AM
StarfireFan
Aug 28, 2009 03:30 PM
Willidog
Jul 10, 2009 11:09 AM
