Fan not working. Is it Fan or Switch
Old Mar 26, 2014 | 02:37 PM
HammerVette's Avatar
I recently purchased a 1970 cutlass. The fan doesn't work, how can I test to see if it's the fan or the control switch that is broken.
The heat/AC fan speed switch doesn't click through the steps from slowest to fastest speed, it slides. Is this normal for 1970, it wasn't in a 1977 or 1986 GM car that I owned.
Thanks for the help.
Jim
Old Mar 26, 2014 | 03:44 PM
jag1886's Avatar
Go by a $10 test light and poke around a little.
Old Mar 26, 2014 | 04:16 PM
Octania's Avatar
The obvious first step is to pull the wire at or near the blower, and see if it has any voltage when it should. It's common for the brushes to simply wear away in the motor.
Old Mar 26, 2014 | 04:19 PM
how about the switch in the car, should it slide up and down or have 4 distinct positions?
Old Mar 26, 2014 | 04:40 PM
Octania's Avatar
I am not familiar with that model so much, but if there is no voltage at the motor, that would be a good thing to look at next. Maybe take a peek at it under the dash and see if it has obviously fallen apart. Buy a new switch for general principles, and see how it feels? A good thing to have a spare of either way.
Old Mar 26, 2014 | 04:42 PM
Lonestar's Avatar
Still on the planet...
Hey Jim, I went out in the shop to make sure and mine has 4 distinct "detents" in the switch; Off, Lo, Med, Hi. Good luck with the diagnosis!
Old Mar 26, 2014 | 05:16 PM
Thanks guys, I will take a look tonight.
Jim
Old Mar 26, 2014 | 06:38 PM
Lady72nRob71's Avatar
This is correct. Also the same detents are in the AC fan switches.
Old Mar 26, 2014 | 07:34 PM
Yeah, the good thing about the GM blower systems is that they were essentially unchanged for over 20 years, so whatever you know about the '77 or '86 probably applies pretty closely to the '70.
And I've never seen one of those switches just "happen" to lose its detents - I'd imagine someone took it apart.
Keep the pieces, as it is likely that you can put the internals from a different year into yours in case you have any trouble finding just the right lever, etc.
oldspackrat
Mar 3, 2015 05:00 PM
Dshelvy
Oct 9, 2013 06:36 PM
holidaysedan
Mar 10, 2011 11:10 AM
Calvin.Norris
Nov 27, 2007 06:08 PM
<KEN>
Sep 22, 2004 08:39 PM
