External VR to Internal VR upgrade!
Old Apr 19, 2017 | 04:26 PM
Stevec's Avatar
Will either a cs130 or cs144 alternator fit my 1968 442 alternator brackets? Thinking of doing the swap/upgrade!
Old Apr 19, 2017 | 07:58 PM
svnt442's Avatar
Get a 12SI. They can be had in stock form up to 94 amps and will bolt in just fine.
Like this one...
http://www.oreillyauto.com/site/c/de...1468&ppt=C0330
Old Apr 20, 2017 | 05:08 AM
olds 307 and 403's Avatar
Out of Line, Everytime😉
The CS130 will. I bought one that is shown as a stock replacement for my 1988 Oldsmobile Cutlass Supreme Classic, 105 amps. Good luck finding a true 12SI replacement. Most are 10SI chrome case alternators which get very hot and don't last. I also see 12SI fans on 10SI cases and vice versa. The aftermarket should have copied the 12SI, the better fan and more open case was done for a reason, improved cooling with higher amperage.
Old Apr 20, 2017 | 05:54 AM
This is what I put on my 71 98:
http://www.jegs.com/p/JEGS-Performan...50748/10002/-1
Surprisingly, the OE alternator posted above is listed for the same price as the one at Jegs. I'm happy with it so far.
Old Apr 20, 2017 | 11:26 AM
Stevec's Avatar
Thanks guys! I already upgraded the charge wire to 6 gauge. Should I put in a maxi fuse? If so where should I put it and how many amp fuse? I'm looking at a 140 amp alternator I have dual 18" electric fans and electric fuel pump.
Sampson
Jan 9, 2014 12:12 PM
jims2000lt
Nov 22, 2012 08:22 PM
1970_442
Jul 8, 2010 03:30 PM
redvettemike
May 26, 2009 01:09 AM
