Electrical Problems - No turn signals or backup lights
Old Apr 11, 2019 | 03:44 PM
Tjohn8573's Avatar
Looking for some advice with my 1968 Cutlass. I have lost my turn signals and backup light. I have checked the fuse at the fuse box and replaced the flasher under the dash...still no go. Builds are good! Would appreciate any ideas anyone may have.
Thanks Tim
Old Apr 11, 2019 | 03:45 PM
Tjohn8573's Avatar
Thanks Tim
Sorry meant to say that the bulbs are good.
Old Apr 11, 2019 | 04:51 PM
Did you validate you are or you are not getting 12V to the bulb sockets and/or the lines leading to the bulb sockets?
Did you validate you are or you are not getting 12V on both sides of the fuse?
Use a bulb tester or multimeter.
Old Apr 11, 2019 | 04:52 PM
allyolds68's Avatar
If you lost both it’s likely a bad ground. 68 Backup light sockets themselves are known for not grounding but the first thing I’d check is the main ground off the harness that screws into the side of your trunk latch.
Old Apr 11, 2019 | 04:55 PM
^^x2^^
Check the main ground (I believe it's the attachment point to the bumper?) and/or the ground(s) from the wires.
Old Apr 11, 2019 | 05:02 PM
72455's Avatar
1972 U code Supreme
Have you done anything under the dash? I had a similar problem on my 72, but it was just the pass side. After two days if diagnosis only to still not find the issue, I went back to connection for the turn signal switch under the dash. Turns out when I was replacing the driver side heater duct, I partially disconnected the plug for the switch (doh!).
Let us know what you find.
Dave
Old Apr 11, 2019 | 06:53 PM
Tjohn8573's Avatar
I do have voltage on both sides of the fuse. No voltage to the lamp sockets. I did install rally pack gauges. I will check the main and trunk grounds. Thanks everyone!
PM70
Jul 1, 2017 11:55 AM
MJAKS462
Mar 20, 2010 08:39 PM
Pghstarsky
Dec 30, 2007 02:04 PM
wizzy01
Nov 20, 2007 04:03 AM
Pghstarsky
Oct 15, 2007 04:44 AM
