Electric window issue
69 Cutlass S convertible with e windows all of a sudden will not operate. Worked fine the other day and now nothing. Fuse is good but replaced it anyway.
Help with ideas please!
Thanks all.
You know, it really helps if, when you are working under the dash redoing everything, that you plug the wiring connector for the relay back into the relay itself. DUH!!!
Really goes a long way to make things work again.
All is well.
All is well.
Glad to hear it all worked out for you. I had a problem with my blower; it wouldn't work on some speeds, and finally quit all together. I ordered a new blower resistor and then found out the resistor connector had come loose. Same issue - previous work under the dash, but by 'certified' radio installers. Oh well, now I have a spare resistor...
