Electric choke - voltage diagnosis
Old Apr 3, 2021 | 02:10 PM
tgilligan's Avatar
Hi. Can anyone confirm if I'm on the right track or if I should be looking elsewhere for a fast idle cam on a Holley 750 w/ electric choke that is sticking? I took the Olds out for a ride today for gas and then to burn some. Initial warm up and drive to gas station was fine, leaving station was also good but then noticed the RPM's a little higher than normal. I pulled over to check it and the fast idle cam was sticking with each blip of the throttle. I could then manually push the cam down and it would stay until the throttle was blipped again. I took it back home to look at it further. I did not see any obvious binding in the cam or the rods. I then checked the voltage with a multimeter and wasn't getting much of a reading. I checked the voltage right at the oil pressure switch that the choke is getting power from and the prong reads between 2.5 and 6 volts. I doubled checked the meter against the battery and the alternator to make sure it was reading accurately.
Does it sound like the oil pressure switch is faulty and that is causing the choke to not operate properly?
Old Apr 3, 2021 | 02:25 PM
The choke needs battery voltage to operate correctly, your voltage reading is low. Check the feed wire to the oil pressure switch, it should read the same as the voltage to the rest of the car.
joe_padavano
Tech Editor's Desk
98
Nov 14, 2025 01:59 PM
1968_Post
Jul 21, 2020 05:38 PM
mcox8051
Nov 11, 2015 02:49 PM
m371961
Ninety-Eight
Aug 16, 2015 06:11 AM
Tedd Thompson
Mar 24, 2013 06:52 AM
