elect. sensor
Old Apr 5, 2012 | 03:47 PM
oldgold's Avatar
elect. sensor
I have a 71 cutlass with a 350 2bbl.On the lower left front of engine just above the pan i have a Elect.sensor.Anybody know what it is.Thanks,Tom.
Old Apr 5, 2012 | 05:29 PM
Lady72nRob71's Avatar
Can you post a picture? Its not a block heater is it?
I wonder if someone threaded in a coolant temp switch in the drain plug opening?
Old Apr 5, 2012 | 06:46 PM
If it has a piece of heavy 2-conductor wire going from it to a 120VAC plug, it's a block heater.
Old Apr 5, 2012 | 06:54 PM
Yup, what Rob and Eric said. The 71/72 350 doesn't have any electrical sensors other than the oil/coolant senders. The block heater could be on either side of the block. Install was simple: Drain the rad, pop out one of the frost plugs and install the heater.
pbarney
May 11, 2014 10:57 AM
jaco
Jan 5, 2007 08:57 PM
bearls
Dec 17, 2006 06:37 PM
beebee007
Aurora
Aug 17, 2006 06:45 PM
DonFrost
Ninety-Eight
Jul 12, 2006 03:58 AM
