downshift switch
downshift switch
Got a 74 cutlass and the downshift switch that mounts on the gas pedal is gone. is there any reason why i couldn't use a $5 push button switch from autozone instead of buying the original part? It just completes a 12V circuit if i understand it correctly.
Thanks.
Thanks.
Thanks.
Thanks.
AT- I was thinking you had a 72 with a 74 455 in it and we decided that by the VIN it was originally a 350 car? Or is this a different car you're working with now?
A 350 car would not have had an electrical downshift switch as Turbo 350 used a cable-operated downshift. A factory 455 car with Turbo 400 would have had it.
84oldsDelta88
January 19th, 2010 11:04 AM
