Which distributor, coil, and spark plug wires should I use?
![Question](https://classicoldsmobile.com/forums/images/icons/icon5.gif)
I have a '66 330 cid and I wanted some insight on which distributor, coil, and spark plug wires you guys would prefer.. I was looking at Mallory for all 3 as a possible choice, what do you guys think?
thanks
thanks
It really doesn't matter. Stock AC Delco is fine.
You will gain no performance advantage from fancy "hot rod" wires in a stock motor, so, unless you like to spend money, stock is fine.
Also, in my opinion, brightly colored wires look silly.
Ohhh Mannnn
Get quality parts. I have a stock distributor with a Crane XRi electronic conversion. I am happy with it if you don't want to mess around with points. I am also running E3 spark plugs. I swapped them from A/C. I don't feel any difference power wise but it does seem to idle a little smother.
327supreme
February 15th, 2009 05:45 PM
dan2286
February 5th, 2009 06:42 PM
