difference between a 70-72 tic toc tach and 68-9
Old October 1st, 2009, 12:41 PM
Eddie Hansen's Avatar
I did do a search but there was no info what is the difference between the 70-72 and 68-69 rally packs? I know they look slightly different but can you use the 70-72 gauges in a 69? anybody know? are they the same size etc?
Eddie Hansen is offline
Old October 1st, 2009, 12:45 PM
ok search wasn't big enough....
I found this answer on another site sorry to bother ya fellas
Note that while they look similar, the 1968-69 Rally Pac will not interchange with the 1970-72 Rally Pac. The mounting ears are different - the 1968-69 set mounts to the individual plastic bezels and must be removed and installed from under the dash. The 1970-72 units mount directly to the dash plastic and can be removed and installed from the front of the dash after removing the chrome/woodgrain one-piece bezel. "
Karaaaaaaaaaaappppppp!! LOL
70cutlasssupreme
January 24th, 2022 02:30 PM
gdam
March 10th, 2008 05:40 PM
TheRuss
May 23rd, 2007 03:57 PM
Quick Reply: difference between a 70-72 tic toc tach and 68-9
