Did I buy the wrong plugs, again
Old Feb 24, 2008 | 05:40 PM
Redog's Avatar
Question Did I buy the wrong plugs, again
When I put the motor in the car, I had the points set-up and I put in the ACDelco R45S plugs. I found out that those plugs were for the 1968 455 motor, and not the 350 like I thought in the first place.
Today I just installed a new set of R43S plugs, The plugs that are for the 1968 Olds 350 motor.
Car runs great, doesn't have that little shake at idle that it did with the R45S plugs, but now I'm running a 1978 HEI distubtor from a Cutlass, should I have bought the plugs for that distubtor ( CR44TS, CR45TS, R44TS, or R45TS ) or will the R43S plugs be fine?
I did gap every plug to .045
Old Feb 24, 2008 | 06:05 PM
J-(Chicago)'s Avatar
Seasoned beater pilot.
Is your distributor from a vin "R" or vin "L" 78' 350 motor?
vin "R'' motors are .060 and vin "L" were .045
Old Feb 24, 2008 | 06:17 PM
Redog's Avatar
I have no idea.
I only found out it was a 78 dis because I replaced the advance.
It did run good, but made that cyl sturggling noise when pushed
I bought it at a swap meet
Old Feb 24, 2008 | 06:41 PM
Well amigo, The best thing that I can think of would be to get a few sets of plugs and try different gaps.
the best thing to do would be to get it on a shop dyno and get your timing curve adjusted for the most hp that you can squeak out of that thing. It's probably 50 bucks an hour, but you may gain 30 horse out of it.
Old Feb 25, 2008 | 03:39 AM
88 coupe's Avatar
Junior Member
Originally Posted by Redog
........ should I have bought the plugs for that distributor ........
The distributor/coil has nothing to do with anything. Use the plugs that match the engine.
........ I did gap every plug to .045
Use the gap that matches the engine. Any gain, from using a larger gap, will come from the placebo effect.
You've been misled, by the "experts" because the concept seems to be too simple for them to grasp.
Norm
Old Feb 25, 2008 | 04:45 AM
Redog's Avatar
^^ Thanks Norm.
I know you know your stuff
Old Feb 25, 2008 | 01:44 PM
I learned something too
Old Feb 26, 2008 | 06:43 AM
88 coupe's Avatar
Junior Member
Thanks Norm ........
You're welcome.
Norm
bob p
Apr 10, 2015 01:55 PM
Dave Siltman
Mar 28, 2012 07:08 PM
rkk69olds
Jan 4, 2011 04:43 PM
rocketraider
Jan 30, 2010 02:37 PM
72Cutlass
Feb 14, 2008 04:36 AM
