Delta 88 wont start after powered Windows repair
Old Yesterday | 03:31 AM
AMD Geode's Avatar
Question Delta 88 wont start after powered Windows repair
Hi every one.
I bought myself a Oldsmobile Delta 88 from 1989 and i realy like it. But the co driver powered window hat a problem. I could lower the window with the switch but it want come back up. I dismantled the co driver door and testet some wires. After a lot of work i managed to get the window back up but i may shorted something out. The only wires i realy touched where the wires directly on the switch itself. No other wires. I even uploaded a image with a wire diagram and marked the wires i touched with a red circle
After i reassembled everything i checked if the powered windows fuse was ok and even testet it with the back windows and everything worked. But since then, the car wont start anymore. I also checked the fuelpump by directly giving it 12V and it runs just fine. Also when i turn on the ignition i can hear the fuelpump for about 2 seconds. So that seems to be working but the car wont start.
It seems like i dont get any sparks on the sparkplugs. And now i wonder if there is maybe a fuse or relay i missed that i may have busted or maybe even smoked the Ignition modul or something elso.
Does anyone have an idea?
Delta881974
May 22, 2025 06:08 AM
prlynch01
Apr 21, 2023 08:26 AM
72cutlassdog
Non-Olds Engines
Mar 17, 2014 09:47 AM
fdwheelman
Aug 9, 2012 06:31 AM
ent72olds
Jul 25, 2012 06:42 AM
