Dash Bulbs
Old May 25, 2018 | 08:40 AM
slickdriver's Avatar
Dash Bulbs
I have a 1983 Olds Custom Cruiser wagon with some burned out instrument panel bulbs. Are these bulbs replaceable? And if so how easily can they be accessed? Also, does any one out there know the bulb size and type without having to dismantle the dash panel first?
Any help would be greatly appreciated.
Dave
Old May 25, 2018 | 10:37 AM
Dave
The bulbs are 194s. You need to remove the face plate from the dash, then the plastic instrument carrier to access the bulbs. You will need to remove the headlight switch **** to get the face plate off and you will have to unclip the speedo cable from the back of the speedometer to get the carrier out. Be aware that the face plate has tabs that snap into metal clips on the carrier. These tabs break easily, as do the features on the carrier that hold the metal clips. It's likely that some of them will already be broken from age (these were not the finest-quality plastic materials...). Also watch for flying metal clips, as they often come loose when you remove the face plate.
Old May 25, 2018 | 05:07 PM
Joe, Thanks for the advice. Sounds like I am going to need small hands and surgeon's tools. All I need now is patience and motivation.
Dave
RandyW
Mar 22, 2017 08:08 PM
rmoths
Dec 23, 2012 11:09 AM
Redog
Jun 25, 2012 04:30 PM
ELECMAN
Mar 5, 2012 08:21 AM
dennisspeaks
Sep 26, 2011 07:20 PM
