Courtesy Lights
Courtesy Lights
I have a 69 442 conv. My question is when you turn your light switch, all the way to the left for courtesy lights, are both the front and rear lights supposed to come on or just the rear? On my vehicle, only the rear courtesy lights come on.
mrolds69,
Thanks for the response. I have confirmed, that on a convertible, when the door is opened, all lights come on.
When the doors are closed and you turn the light switch all the way to the left, this operates the rear courtesy lts. When you turn on the lt, above the radio, it comes on along with the front under dash lts. I have corrected both problems that I was having. Both were chassis ground problems.
