Convertible Top Fuse/Breaker
Old Jan 6, 2023 | 06:23 PM
Falkon's Avatar
1971 Cutlass Supreme. I've been checking all the wiring, to be sure all stays well. Would like to get this straight & understand it correctly. I bought the car last summer. I have the Factory Manual & blew up the wiring diagram. Also looked in the Assembly Manual & didn't see a specific fuse or location for my power top, or power windows. It appears there is a fusible link in the wire to the interior (fuse box, lights, ign. sw.). The line to the highspeed blower (A/C car) should have it's in line fuse. Is that circuit breaker located on the firewall behind the power brake the one I'm looking for? Does it "fuse" both the top & windows? Is the relay above the brake master on firewall power top relay? Window relay is behind left kick panel I believe.
Old Jan 7, 2023 | 06:35 AM
The circuit breaker is located on the firewall below and outboard of the brake booster, above the main firewall harness connector. It is fed with a wire from the horn relay junction block and the wire from the breaker passes through a multi-hole firewall grommet.
Old Jan 7, 2023 | 07:58 AM
The breaker diagram is located in the PIM. A search of my username w/ keyword breaker will most likely reveal the thread(s) I’ve posted such diagram. But, as I said it’s located in the PIM (some refer to as the FAM).
Old Jan 7, 2023 | 08:04 AM
Falkon's Avatar
Thank you both. I'll research the Assembly Manual again. What started me on this mission is that I noticed there was a taped connection where I believe the inline fuse for the A/C high speed blower should be. I just want to verify that all the car's circuits are properly fused. I once bought a rebuilt salvage Mark VII that had the sunroof hotwired w/o a fuse. I discovered this the hard way. Burnt wires. Now I double check new purchases. Thanks again.
Al
Old Jan 7, 2023 | 08:35 AM
Specifically in section 12, Electrical.
Old Jan 7, 2023 | 02:58 PM
More specifically, page 132.
Old Jan 7, 2023 | 03:37 PM
Falkon's Avatar
Thanks again for confirming everything. I also saw a picture of behind the dash power top wiring harness. It's not a schematic though. I assume that power feed through the accessory grommet goes to the power top's switch in the dash. Then 2 wires (up & down) run back to the top's pump. Wire from circuit breaker into the car looks like it's been hot. I ordered one of those "snake" cameras to better see behind things. Picture above shows/says the power windows also feed off that firewall breaker. Strange, I thought mine were powered from the 3rd tab down (ign.) on my fuse panel by a heavy wire running to the power window relay behind the kick panel. I'll just pull off the wire to confirm it. Those wires seem OK. Now I need to reinstall a fuse in the feed wire from the horn relay junction to the blower A/C high speed relay. It is missing entirely, & there's a taped over joint in the wire. Slowly beginning to understand the car thoroughly.
Old Jan 7, 2023 | 03:43 PM
Falkon's Avatar
Here's a poor picture of my fuse block. There is nothing in the top right slot. No tabs even. Top left has a fuse I can't quite read. I think it should be accessory or heater. Waiting for my camera. I'd need to remove the left side A/C duct to get at the panel better. That big wire is the one I think leads to the windows. It's not white, that's a reflection. Thanks again. Gaining a better understanding all the time.
Old Jan 7, 2023 | 03:47 PM
Color code(s) for wiring harness from front harness to rear harness is contained in the Fisher Body Service Manual which demonstrates wiring to convertible top motor(s).
Old Jan 7, 2023 | 06:36 PM
Also in the PIM Section 12.
Old Jan 9, 2023 | 08:22 PM
Falkon's Avatar
Thanks everyone, I think I have it figured out. I found the circuit breaker behind the brake booster. It has 2 wires leading into the car. One goes to my power top switch, & the other to the power window relay. That relay (behind the left kick panel) is triggered by that red wire on the fuse block ign. terminal. One of those 2 wires looks like it was overheated & melted a little bit. I will investigate further (everything works) & replace it if needed. I'll also install a fuse in line for the one missing in the blower feed to the blower relay located above the brake booster. I conclude the power top has no relay. That should do it & make the car safe again.
Al
ragtopblue
Jul 7, 2021 05:49 PM
matt69olds
May 29, 2020 07:51 PM
Steven Hall
Mar 30, 2019 04:39 PM
1robert
Nov 19, 2016 07:31 AM
Mark71
May 20, 2011 02:44 AM
