Convertible Switch Same as Rear Window Switch?
Old Oct 30, 2016 | 06:39 PM
CuttyShark's Avatar
I have a dash complete with a "Rear Window" switch. I am going to use that Dash in a Convertible. The switch for a convertible top is WAY too much money for just a switch. Is the switch the same? Anyone with a Wagon/Vista Cruiser know if the switch is the same? I have no basis for comparison.
Old Oct 31, 2016 | 03:13 AM
Yes, the internal parts of the switch are the same.
Old Oct 31, 2016 | 06:36 AM
oldspackrat's Avatar
Yes, what Eric said.
Old Oct 31, 2016 | 02:19 PM
CuttyShark's Avatar
Great!so in theory I just move the switch over to the area where the convertible switch is so that when I put the Woodgrain appliqué on top it's where it needs to be! And the harness will then plug into it?
Old Oct 31, 2016 | 03:07 PM
I have seen the convertible top switch in both extra locations in the dash so I would not even worry about switching the location just install the dash and plug the harness into the back of the switch and you should be good.
Old Oct 31, 2016 | 08:14 PM
CuttyShark's Avatar
I would.... however the Woodgrain kit I have has the cutout one space to the right. :-/. It's too late to return it. I'll eventually install OEM cruise control so maybe I'll use that spot later
cfair
Ninety-Eight
Jun 23, 2019 07:49 AM
wyteon
Vista Cruiser & Wagons
Nov 30, 2018 11:33 AM
mikemickunas
Sep 12, 2012 07:15 PM
Curth
Sep 2, 2010 08:40 PM
jeffreyalman
Jun 6, 2009 06:28 PM
