convert 1970 toronado idiot lights to 1966 gauge??
Old Aug 23, 2012 | 08:36 AM
EightballZ's Avatar
hey guys,
last night i was looking at some dashboards from 1st gen toros...
my 1970 toro only has these idiot lights but a 1966 toro has real gauges for water temp and battery.
do you guys think that it is possible to put that water temp gauge in my 1970 toro?
i guess i need to change at least the temp sending unit(s)? what about the wiring? you can see that the 1970 panel has 7 connector pins while the 1966 panel only has 6.
here are the panels:
http://www.ebay.com/itm/1966-Oldsmob...637d5d&vxp=mtr
http://www.ebay.com/itm/1970-Oldsmob...item3f1a33c0ed
Old Aug 23, 2012 | 09:06 AM
With the right tools and enough determination, you can do anything.
Old Aug 23, 2012 | 11:25 AM
EightballZ's Avatar
ok...i recently found out...that the 1966 toro has only 1 temperature switch while the 1970 toro has two of them (and it has 2 idiot lights).
so maybe that is plug and play...change the temp. switch in a 1970 toro to one from a 1966 and change the panel...no need to touch the wiring harness...afaik.
Old Aug 23, 2012 | 12:53 PM
rocketraider's Avatar
Oldsdruid
I think you'll be able to change them by rearranging some wires on the plug. To use the ammeter may require some different wiring around the main splice.
The two temperature switches on 68-70 are for two different things. The "HOT" warning lamp is triggered by the temp switch on the intake manifold. You will also see a "STOP ENGINE" warning light in the same pod as the HOT light. That one is triggered by a temperature switch mounted into a special bolt on the LH cylinder head and is the 7th wire you see on the 1970 panel.
I always figured if the cylinder head got hot enough to trigger that lamp, some serious damage is already done. To test its operation, with ignition ON, lift the wire off it and ground it to the engine block. If it's like my 69, it will light and then begin to flash.
Old Aug 23, 2012 | 01:05 PM
EightballZ's Avatar
that is exactly the info i need...thx for that.
definately gonna try that with the temp gauge...dont really know about the ammeter..we'll see
thats why i want to have a gauge..it will tell you there's something wrong BEFORE damage is done
Old Dec 4, 2013 | 11:31 PM
68RocketAction's Avatar
Just wondered if you ended up trying this and what the outcome was...
I have wondered if this would work myself. I seriously hate idiot lights. I have been extremely tempted to just buy a gauge cluster from a 1966 or 1967 to see if it would work. However, I would seriously hate to go to the trouble of removing my instrument panel, moving over my speedometer, hooking it back up, and it not work...
That entire dropping the steering column and removing the drivers side portion of the dash is a serious pain. Although that is the only way to get access to everything...
Old Dec 5, 2013 | 01:12 AM
EightballZ's Avatar
yeah it tried this..you have so switch the wires that feed the idiot lights..and you also have to install the correct switch on your intake manifold..but thats plug and play.
it definitely helps to have wiring harness diagrams of both..donor car and your car.
i could'nt figure out why the indicator needle shows full heat while cranking the engine...it drops back immmediately as the engine runs
as for now i've installed an aftermarket gauge just to see that the original gauge was right...engine ran to hot...so i'm rebuilding it
Old Dec 5, 2013 | 02:32 PM
Great!!! I think I will study it a bit and give it a shot...
snowman
Sep 13, 2014 04:22 PM
Margie's68
Jul 6, 2014 04:08 PM
mruders
Jun 3, 2014 06:00 PM
Sampson
Sep 26, 2013 06:11 AM
Jolly Green
Mar 15, 2009 06:21 PM
