Connection Point for Electric Choke Installation
I am in the process of installing an electric choke (purchased from carbjunkys.com, Atlanta, GA) on my 1976 Cutlass Salon and I need advice as to which circuit I should splice its power wire into. I have decided to go this route because every component in the manifold heat stove system would have to be replaced for the hot air choke to function correctly.
Suggestions?
Jeff
Suggestions?
Jeff
If your going that route, the IGN terminal is already fused through the taillights 20A. So an additional one is sort of redundant. I use the IGN terminal for this and HEI power with no issues. I like Joes way also, its just a more complicated approach as here in Texas a choke is not much of an issue.
442stang
Cars Wanted
May 27th, 2012 06:56 PM
