Connection Point for Electric Choke Installation
Old Feb 19, 2016 | 05:46 AM
76CutlassSalon's Avatar
I am in the process of installing an electric choke (purchased from carbjunkys.com, Atlanta, GA) on my 1976 Cutlass Salon and I need advice as to which circuit I should splice its power wire into. I have decided to go this route because every component in the manifold heat stove system would have to be replaced for the hot air choke to function correctly.
Suggestions?
Jeff
Old Feb 19, 2016 | 06:08 AM
Here you go:
https://classicoldsmobile.com/forums...ke-wiring.html
Old Feb 19, 2016 | 09:41 AM
My442's Avatar
The safest way is run a 12 gauge wire with an inline fuse from the IGN spade on the fuse box to the choke.
It is a key operated 12 volt source, and the fuse protects you from a electrical surge.
Old Feb 19, 2016 | 10:27 AM
This is what I did and it works well.
Old Feb 19, 2016 | 11:13 AM
If your going that route, the IGN terminal is already fused through the taillights 20A. So an additional one is sort of redundant. I use the IGN terminal for this and HEI power with no issues. I like Joes way also, its just a more complicated approach as here in Texas a choke is not much of an issue.
Old Feb 19, 2016 | 12:34 PM
hookem horns's Avatar
Not elegant, but you can tap the wiper power too.
Old Feb 20, 2016 | 06:38 AM
Why to people like to do this? It's really easy to simply wire the electric choke the way the factory did. See the link above.
240 Gordy
Oct 11, 2020 10:04 AM
442stang
Cars Wanted
May 27, 2012 06:56 PM
mp71conv
Jan 21, 2009 02:28 PM
woodie582
Nov 7, 2008 01:07 PM
justinj
Nov 5, 2008 06:07 PM
