Computer on an 85 cutlass salon?
Old Aug 27, 2007 | 05:26 PM
TheBiggness's Avatar
What can I do to disable it?
Old Aug 29, 2007 | 03:22 PM
I was told I had to buy a 3 wire distributer, but i was hopeing I might not have to.
Old Aug 29, 2007 | 07:07 PM
First, why do you want to disable the computer? Second, if you are required to have the car emissions tested where you live this is grounds for failure. Third, what engine do you have?
At a minimum the computer controls the distributor advance, the carb primary side mixture, the idle speed, the trans converter lockup and the evaporative canister solenoid. On the VIN Y 307 it also controls the A/C compressor clutch. At a minimum, removing the computer requires that you change the distributor to an older HEI with a vacuum advance canister and the carb to an older Qjet without the mixture control solenoid. If you still have a lockup converter trans you'll need to rig a switch or get an aftermarket lockup controller. None of this will provide dramatic improvements to a 307, which runs pretty well if all the factory installed equipment is working properly (including the miles of vacuum hose).
Old Aug 29, 2007 | 10:48 PM
Redog's Avatar
Yeah it's kinda pointless to disconnect it. The car will not run correclty.
If the ECU bothers you that much, put classic plates on the car and change to motor with something bigger and no emissions
Old Aug 30, 2007 | 05:31 AM
Definitely keep your computer. It would be a hassle to remove the ECM and all of the sensors without affecting the way the car runs. Like everyone said, you wouldn't get that much of a power increase anyways. The early GM computers worked well, I had a 1990 Buick Estate wagon with a CCC Quadrajet and it got decent gas mileage for such a big car, and it ran so smooth you could hardly even tell it was running.
Allan R
Oct 16, 2009 01:46 PM
72hopilot
Sep 17, 2009 12:18 PM
junkyardjeff
May 3, 2009 08:03 PM
marcar1993
May 1, 2007 11:35 AM
