Coil specifications
Old Sep 10, 2008 | 09:26 AM
scott_442's Avatar
Coil specifications
Anybody have the resistance numbers, both primary and secondary, for a 1972 350? Also, how far out of spec is replacement warranted? Thanks.
Old Sep 10, 2008 | 02:15 PM
I doubt there is a measurement available for that. I am sure the engineers knew what it was, but a coil either works or it doesn't. Take the coil wire off and ground it to the frame or engine, then have a buddy crank the engine over. IF you see your coil wire sparking then it is good. If it doesn't spark then your coil might be bad.
Old Sep 10, 2008 | 04:53 PM
Bluevista's Avatar
Registered
The general specs in the chassis electrical section in my '71 service manual shows primary resistance for a V-8 coil at 75 degrees is 1.77 to 2.05 Ohms. The secondary resistance is .6500 to 9500 Ohms.
Not sure if they would be the same for yours or not.
Allan
Old Sep 10, 2008 | 10:59 PM
BILL DEMMER's Avatar
Just the facts...
a resistance test isn't that reliable of an indicator. sure, it will show a hard-short, but since we're talking about something that is essentially a step-up transformer, the only way to test for breakdown would be a high-voltage probe. those aren't very common these days. if you're in doubt about your coil-just replace it.
bill
2blu442
Mar 5, 2010 02:27 PM
Prsabordo
Mar 3, 2010 02:38 PM
oldsmerc
Sep 23, 2009 10:09 PM
FATRATMATT
Apr 11, 2009 05:06 AM
442 Guatemala
Feb 19, 2009 07:20 PM
