Coil Connections
Old Apr 14, 2025 | 07:57 PM
72Vert442's Avatar
Coil Connections
There are two connectors coming from the main harness that connect to the coil. One connector has 1 wire and the other connector has 2 wires. Which one goes to positive or negative on the coil? I have the Distributor wire on the negative side. Condenser wire on the positive side. I marked the wires but the tape came off.
1972 Olds 350/350.
Old Apr 15, 2025 | 04:20 AM
The two-wire terminal goes on the pos side. I'm thinking the last wire is the tach, need wire color to confirm, goes to neg side.
Old Apr 15, 2025 | 06:27 AM
The power wires (from starter and ignition switch) go to the "+" side of the coil. The black wire from the distributor goes to the "-" side of the coil. If you have a tach, that wire also goes to the "-" side.
MZ832
Aug 20, 2024 01:48 PM
6844268
May 3, 2023 03:32 PM
Andy
Aug 7, 2020 04:29 AM
Danny Boy
Jul 28, 2014 01:46 PM
mp71conv
Oct 21, 2007 10:49 AM
