Coil Connections
Coil Connections
There are two connectors coming from the main harness that connect to the coil. One connector has 1 wire and the other connector has 2 wires. Which one goes to positive or negative on the coil? I have the Distributor wire on the negative side. Condenser wire on the positive side. I marked the wires but the tape came off.
1972 Olds 350/350.
1972 Olds 350/350.
The power wires (from starter and ignition switch) go to the "+" side of the coil. The black wire from the distributor goes to the "-" side of the coil. If you have a tach, that wire also goes to the "-" side.
