Clutch Safety Switch wiring, '70 Cutlass
Old January 12th, 2018, 12:29 PM
BSiegPaint's Avatar
1970 Cutlass 4-speed - the safety switch is still installed on the pedal, however the two purple wires in the harness that this switch should be connected to have been removed from their double plug and taped together, bypassing the clutch switch. The jumper wires between the harness and the switch are missing, but easily replaced. I'd like to connect the purple wires correctly. Is there any way to tell which of these two wires goes to which pole on the switch itself? Or better yet, if I choose incorrectly, will I screw something up by wiring it wrong?
BSiegPaint is online now
Old January 12th, 2018, 01:25 PM
frankr442's Avatar
It doesn't matter. It just makes/breaks the connection.
frankr442 is offline
Old January 12th, 2018, 01:28 PM
X2 it does not matter.
oldcutlass is online now
Old January 12th, 2018, 01:32 PM
BSiegPaint's Avatar
Outstanding - thank you!!!
Old January 12th, 2018, 01:39 PM
My442's Avatar
Pull the clutch switch and test it with a test light or a meter.
Looks like the picture.
My442 is offline
Old January 12th, 2018, 03:57 PM
BSiegPaint's Avatar
Thanks, My442 - I have continuity between the posts when the clutch pedal is pushed in fully. No reading when it is not.
BeenThere
December 12th, 2015 04:53 AM
BeenThere
November 1st, 2015 05:37 AM
oldspackrat
November 17th, 2014 06:31 AM
spate51
August 7th, 2012 08:50 AM
Dave Siltman
Tech Editor's Desk
May 6th, 2010 06:48 AM
Quick Reply: Clutch Safety Switch wiring, '70 Cutlass
