"Check Engine" light burnt out?
Old Jan 30, 2007 | 05:11 PM
sean000's Avatar
Anyone know if there is a way to retrieve the ECM codes without the use of the "check engine" light?
How hard would it be to replace the bulb in the check engine light on a 83 cutlass?
Could there be another reason the check engine light isn't coming on at all...not even on start up?
Thanks in advance,
sean000
Old Jan 31, 2007 | 05:03 PM
ozoneblue's Avatar
Wink Check Engine Light
Test all your fuses with IGN on & park lps on All fuses should have power Check with 12v test light .Also check small wire at ALT should have power with ign on
panther80
Sep 17, 2012 07:30 AM
HouTXCutlass
Aug 16, 2010 11:06 AM
dhoff
Mar 6, 2010 06:47 PM
JACK RYAN
Intrigue
Dec 28, 2008 09:27 PM
