Can someone with knowledge in early 80's Delta 88's give some guidance?
Old Mar 10, 2015 | 10:22 AM
dredluxx's Avatar
the hot box
Hey guys. I'm in need of some direction. My 1982 Delta 88 has an AM/FM radio. However, it's driving me crazy, and i need something with a tape deck. Did any 1980-1985 Delta 88's come with cassette decks in their factory radios? Is the radio a direct swap? I want a cassette deck so i can play my own music with a cassette tape that has an aux cord hooked to it. I want my own music but i dont want to drill some big ugly radio into the wood just so i can have an aux hookup.
Any information would be appreciated, and I would be highly thankful to anyone who could point me in the direction of a Olds factory radio with a cassette deck that I could put in my Delta!
-dredluxx
Old Mar 10, 2015 | 11:11 AM
rocketraider's Avatar
Oldsdruid
Double-shaft AM-FM-cassette radios were available for your Delta. It doesn't have to come from an Olds- by then all GM Divisions used pretty much the same radios, just ***** were different between carlines. You can count on replacing the tape drive belt if you plan to listen to cassettes at all, but the adapter thing should work OK even if the drive belt has broken.
Sometimes you'll find a radio that has different wiring plugs. I know Buick didn't switch over to the Olds-Pontiac-Chevy wiring till around 1981.
Old Mar 11, 2015 | 02:29 AM
Yellowstatue's Avatar
Go to the wreckers and check the Ninety-eights for your desired radio. Easy peasy.
Old Mar 11, 2015 | 03:13 AM
Oldsdruid
Forgot to mention some of them are even digital display ETR units.
RandyS
Body work
Mar 23, 2015 03:02 PM
seeyah
Sep 16, 2013 03:35 PM
Miniboom
Wheels and Tires
Jun 28, 2012 07:42 AM
gearheads78
Feb 11, 2011 04:37 PM
godson
Dec 29, 2008 09:35 PM
