Can Anyone Tell What Belongs in These Cutouts?
Can anyone tell me what belongs in the 2 cutouts near the power top switch on my 68 Cutlass S convertible? The car is highly optioned, so I figure it's likely for switches or something. The cutouts look factory cut.
Thank You,
Tom
Thank You,
Tom
That's a good possibility. Maybe the small hole is for the map light switch. I'm sure that's a real easy option to find (sarcasm). I was hoping it would be something easy. It may be easier to find another dash without the holes.
Thanks,
Tom
Thanks,
Tom
The attached photo shows the map light on the dash of my '73 Custom Cruiser. I know it's not a '68 Cutlass, but the shape is the same, and that's what made me think of it. The switch for the light is actually with the light and not in a separate cutout. I would guess that, if that long opening in your car is for a map light, it would be the same, and the other cutout could just be for a courtesy light. There are courtesy lights on either side of the map light in my photo. They go on when the headlight switch is pulled out.
Thanks guys. The car was this way when I bought it. Judging by the options the car has, I would bet the dash is original. The car has an aftermarket power rear antenna. It is likely a replacement for an original power antenna and was hooked up directly to the aftermarket radio.
How difficult do you think it will be to find a map light and a power antenna switch??
Thank You,
Tom
Thank You,
Tom
Gotta find someone with '68 Cutlass parts or someone parting one out. Fusick has lots of Cutlass parts and switches in their catalog, but I didn't see either of these.
Rocket Richard
August 22nd, 2012 12:37 PM
