A/c ?
Old Dec 28, 2016 | 04:58 PM
sammieolds's Avatar
A/c ?
Hi everyone I notice on my 74 CS the heater works on low to high,
But when I but the A/C on it blows high no matter where the switch is on low or high That's not right any ideas why ,Plus how hard is it to replace front speakers on a 74 and can I get the same size
Thanks all
Steve
Old Dec 28, 2016 | 06:04 PM
How is your heater control supposed to work?
I would check the Owner's Manual to see.
Some years/models have a "Max A/C" setting that runs the fan on High, and then step down to normal speeds at the regular A/C setting, and if yours if keeping to high on both, you could have something out of alignment inside your selector switch.
Old Dec 29, 2016 | 06:55 AM
Steve, you should be able to get speakers for your car at any quality audio shop or even Wal Mart. Here is a good on-line supplier:
http://www.crutchfield.com/
Old Dec 29, 2016 | 07:57 AM
sammieolds's Avatar
Thanks guys
Old Dec 29, 2016 | 09:20 AM
Fix it, fix it now!
Old Dec 31, 2016 | 01:27 PM
rocketraider's Avatar
Oldsdruid
3-1/2" speakers. Take the plastic speaker cover off for access and be careful as the part is known to break.
MAX A/C will put blower speed on high and set the HVAC doors to recirc so you're simply recirculating already cooled air at high velocity. A/C position should allow all blower speeds. Possibility yer control head lever is a little off, or the high blower relay may be sticking.
Old Jan 1, 2017 | 08:54 AM
texxas's Avatar
Most of the 3 1/2 speakers have too big of a magnet to fit in the tight factory supplied space. It is not as easy as other have mentioned to get speakers that will work. I have seen people clearance the ductwork in the dash to get a little more space for the magnet to fit and I have ground off the bottom side of my speaker cover to gain a little more space so the cover sits flush. The smallest speakers I could find a few years ago were Blaupunkt and they were still larger than the space available. When I replaced my dash with a better condition piece I left the front speakers out for the time being as my speaker cover is mint condition and I can't bring myself to grind on a perfect cover.
Old Jan 2, 2017 | 03:49 PM
sammieolds's Avatar
I don't blame you
Old Jan 3, 2017 | 06:30 AM
I am concerned about this as well. I recently bought these speakers:
https://www.amazon.com/BOSS-CH3220-E...5+inch+speaker
They didn't fit under the factory speaker grilles. I bought aftermarket grilles and got them to work. I hope I don't run out of room when I reinstall the A/C controls on the driver's side.
Old Jan 20, 2017 | 01:44 PM
texxas's Avatar
I found these listed and they just may work in the tight dash confines.
http://www.ebay.com/itm/181202166827...%3AMEBIDX%3AIT
Old Jan 20, 2017 | 01:51 PM
On your speakers make sure you match the impedance rating to your radio. 4 ohm speakers will not work.
Old Jan 20, 2017 | 02:13 PM
texxas's Avatar
They will on mine, I have a vintage Alpine in place of the factory 8 track currently.
When I run the factory radio I have used these guys in Dallas to recone my original speakers with outstanding results.
http://freemantuell.com/Default.aspx
