Bulbs for the optional interior lamps?
Old May 1, 2026 | 02:14 PM
Specifically, the ones that are bolted to the bottom of the dash on the left and right. I technically need them for my 81 GMC, they are the same setup. None of the parts stores have a listing, and I can’t read the numbers on the base of the one bulb I have. I found a few bulbs that appear to have the same base.
Old May 1, 2026 | 02:24 PM
1004 or 1004LL (long life) lamp is for the truck.
Old May 1, 2026 | 02:26 PM
They're bolted? Hmmm....lamps aren't bolted, maybe the sockets are bolted...I've not seen lamps bolted to bottom of the dash. And, are you talking about the "courtesy" lamps mounted to the bottom rail under the dash on both the LH & RH side?
Old May 1, 2026 | 02:27 PM
Well, I guess Eric beat me to it.
Old May 1, 2026 | 02:49 PM
Smart ***!!! 😁
yes, the COURTESY lamp SOCKETS that bolt the the underside of the dash on both the left and right.
Old May 1, 2026 | 02:51 PM
Smart ***!!! 😁
Eric had the correct numbers.
Old May 2, 2026 | 06:49 AM
Smart ***!!! 😁
Better than being a dumb @$$...
Chuxter
Mar 2, 2024 01:47 PM
72GoldOlds350
Nov 24, 2019 06:58 AM
rmoths
Sep 26, 2017 10:41 AM
davidstereo
May 11, 2012 08:10 PM
55coupe
May 8, 2012 07:14 PM
