Bonehead move = GEN light on with ignition off
Old Feb 19, 2013 | 11:58 AM
iabc205's Avatar
Hello All,
Thanks in advance for any help you may be able to offer. I recently installed a battery in a 1973 Omega. Here's the bonehead move: the battery that came out had reversed terminals (converted from side post to top post, by the way) versus the battery I put in. You know where this is headed, right?
I connected the cables backward for a moment before I realized what I'd done. There was a spark, naturally. There also was a little puff of smoke that came from the starter area. I immediately removed the negative cable and checked the fuses. None were blown.
I reattached the cables (correctly this time) and started the car. The car starts and runs fine, except now the GEN light stays on, even with the key in the off position. If the key is in the ACC position, it goes out. The GEN light also stays on in the RUN position.
I checked voltage at the battery with the engine running; it's about 13.7v, so the alternator appears to be working.
What did I fry? Regulator? Diode? The whole alternator? Any ideas?
Old Feb 19, 2013 | 12:31 PM
bkeese's Avatar
Diodes
Old Feb 19, 2013 | 02:35 PM
RetroRanger's Avatar
72 Olds CS
IDK what broke but if the diodes were fried IDT you would get 13.7v at the battery w the car running.
Old Feb 19, 2013 | 06:52 PM
rocketraider's Avatar
Oldsdruid
There's a fusible link down at the battery. Look for a brown wire that changes to red on the body side of the fuse link. Another fuse link is in the main harness at the horn relay and junction block. Look for a black wire
If it's a 6-cylinder car there's also a fuse link in the smaller red wire to the alternator.
The way I read the wiring diagram if the main harness fuse link(s) is burnt, there shouldn't be any power anywhere in the car except the coil. If only the alternator fuse link is burnt, you'd still have 12V to the alternator field and rectifier.
I'd have the alternator tested first. If it shows good, then it's time to dig into wiring.
Old Feb 19, 2013 | 06:53 PM
Lady72nRob71's Avatar
If only one diode opened up, there are more to take up the slack. However rather than a full wave rectifier, you could be down to a half wave or somewhere in between. DC volts on a voltmeter will still look 'good'. The diodes can be replaced easily in a stock alternator. Have the alt checked for sure.
Old Feb 20, 2013 | 06:18 AM
Originally Posted by lady72nrob71
if only one diode opened up, there are more to take up the slack. However rather than a full wave rectifier, you could be down to a half wave or somewhere in between. Dc volts on a voltmeter will still look 'good'. The diodes can be replaced easily in a stock alternator. Have the alt checked for sure.
x2
Old Feb 20, 2013 | 02:32 PM
iabc205's Avatar
Thanks for the info. It's a 6 cylinder; sorry for not specifying that. I will check the fusible links you spoke of and get the alt tested next.
N2ROW
Apr 11, 2015 10:04 AM
SouthCarolinaCutlass
Dec 31, 2014 07:33 AM
rktw31
Apr 10, 2012 05:14 PM
ShaunM
Oct 12, 2009 09:52 PM
dynamic88
Jul 7, 2008 12:27 PM
