blower resistor
Old Jun 17, 2025 | 09:39 AM
fitter bill's Avatar
blower resistor
Hi All I Have A 72 Cutlass Blower Only Runs On High Speed .I Pulled The Resistor Out And It Looks Ok. Did A Ohm Check No Opens But I Don't Know What The Spec Should Be As Far The Ohms Any Help/
Old Jun 17, 2025 | 02:38 PM
Tap on the high blower relay.
Do you have a service manual? The diagram is in the book.
Old Jun 17, 2025 | 02:39 PM
Tap on the high blower relay. If that gets the slower speeds going, more than likely the relay contacts are stuck or pitted.
Old Jun 17, 2025 | 03:06 PM
I could not find my manual then finally did , checked the relay not working . removed it and bench tested now working . I think it was intermittent on failing. Replaced relay and tested now good. Thanks for the help.
Jon442
Jan 30, 2018 01:33 PM
carsworthkeeping
Feb 2, 2016 07:23 PM
henryk8398
Sep 20, 2011 04:54 PM
mhood
Aug 12, 2011 10:18 AM
mmcilroy
Jan 25, 2010 04:03 AM
