blower resistor
blower resistor
Hi All I Have A 72 Cutlass Blower Only Runs On High Speed .I Pulled The Resistor Out And It Looks Ok. Did A Ohm Check No Opens But I Don't Know What The Spec Should Be As Far The Ohms Any Help/
I could not find my manual then finally did , checked the relay not working . removed it and bench tested now working . I think it was intermittent on failing. Replaced relay and tested now good. Thanks for the help.
