Battery over voltage
Hello CO, Just an update before I put the car away for a couple weeks. The boat has been calling my name to go fishing and it's time. I spent some time yesterday talking with Stellar (Mark) from this site and we did some troubleshooting. Though we were able to stop the over charging issue with a regulator change. I also added a ground strap to the regulator going to the firewall were it meets the engine ground. Now bat voltage is at 12.5 at idle. Raise the rpm and the volts rise and come back down with rpm. Not over 14.5 volts. Something Stellar mentioned was that with the reg harness disconnected it would do the same thing. Could raising the rpm make the voltage go up with no regulator connected? Anyway I'll start fresh after a rest. Willing to listen to any "sounds crazy but" stories anyone has that may shine some light on my issue. Even if its not crazy. Big thanks to Mark for taking time out to assist. Greg
Don't see how a properly wired, properly working alternator could increase voltage with the regulator disconnected as the field isn't energized when the regulator is disconnected. If it did charge with the regulator disconnected I'd be looking for a short that is energizing the field.
Anyone agree, disagree?
There might exist possibility of a wiring issue, something placing large demand on ALT as RPM increases esp. if you witness this w/ the VR completely removed from the charging circuit. I would not expect ALT to increase voltage output as RPM increases without a VR esp. anything above 15VDC - that’s like a runaway train. It would be odd headlights would influence this behavior “if” wiring was correct, yet you did say you had/have a headlight issue. Any chance your headlights are very, very bright? You might try selectively pulling fuses one at a time and repeat your voltage readings each time to see if perhaps a particular circuit is involved? If you pull a fuse, increase RPM but voltage no longer goes up, up and up you may have isolated the offending circuit.
Does the alternator have a square plug or a rectangular one? Is the alternator an original type Delo? Someone please confirm but, my recollection is a '68 442 should have a square plug external regulator alternator. A '69 442 would be an internal rectangular plug alternator. I realize the OP's car has an external regulator but wondering if someone installed a different alternator.
I would start by replacing the battery cables. I see that you have used repair terminals, and they should only be a very temporary fix for replacing the cables with new. If you were to split the wiring jacket open, there is a very good chance that you will find a lot of corrosion under the plastic that can lead to your problems. As previously said, clean up your wiring issues and then do the testing. Electrical current is dependent of having clean tight connections. Let us know what you find under the battery cables plastic insulation with pictures.
It would be interesting to see the voltage at the battery with everything hooked up at a high idle and then with the regulator disconnected and then with the regulator disconnected and the alternator unplugged at the same time. If it stops charging with the alternator and the regulator unplugged the field wire is getting energized when it shouldn't be with the regulator unplugged. This certainly could be from what Junkman said about corrosion in the harness creating a short circuit OR something is wired improperly. This problem is interesting.
There's a theme here. Unlikely to suspect one size fits all resolution.
(1)
(2)
(3)
(4)
(5)
(6)
(7)
(1)
OK, @ idle, 12.8 this time Lights on @ idle 12.25. 2000 rpm ish15v and continued to rise. I turned on lights and 12.5 steady. I am going to bring up that I had no low beams prior to this and was in the process of looking into it when this all came up and I did not mention it. The low beams are working all of a sudden. The plot thickens.
Under the dash is a mess of wires, after market radio with 6 speakers in the doors alone. Wires everywhere. It seems I should see what's going on with the lights before moving on. I was only able to look at the continuity of the Hi Low floor switch before being pulled away. Could not find an issue with it. What could cause a no low beam situation?
My low beams are not working again
Also found another fusible link
Also replaced the fusible link and installed a correct alt plug.
This may be the problem. Pulled the harness out of the regulator and it fell off.
I noticed that my fuse panel is loose on the fire wall. It wiggles a bit when pulling on wires.
To bring all up to date, All of my playing around with the alt has led to a stripped thread so Im returning it to Napa. Ill post some video when the car is running again later today. Greg
Turning into moot point now as the harness will be here early next week. I will find out why I was having this problem. Where I am now; Got the new alt from Napa and installed. I can no longer get the charge to climb as before. Regulator was new when I walked away 2 weeks ago. Still have the gen light and 12.5 VDC at the battery at idle. ran new field wires to bypass the harness. Same outcome. So, decided to do some cleanup on distribution /fuse block. It was missing a screw so replaced it and tightened it up last Monday but when I removed the fuse for Power relay, top left corner under flasher relay one of the connections is loose inside the panel. I only get 11.9 VDC there and the one below it. All others are 12.5 battery voltage My gut tells me this could be my issue. My question to all is: When the key is on, (not running) I get 12.5 volts at the regulator terminal 4. When the engine is running with reg plugged in it goes down to 3.5VDC. Is this normal? Should it be battery voltage? or perhaps 0? Thanks to all for your input. I bought this car as a way to learn without messing up something nicer. Guess I'm getting my money's worth. Greg
