Battery Draw/Under Dash Sparks
Old Aug 28, 2015 | 08:41 AM
NJ442's Avatar
Hi...Paul here. My battery needs to be re-charged about every 10 days. I must have a bad ground or some other problem that is drawing down the battery. I was under the dash and I accidently touched the antenna lead to the glove box metal bracket and there was a spark and it blew out the courtesy light fuse. I would suspect what happened is associated with my battery problem. How do you suggest I go about fixing this electrical issue? Any help would be appreciated. Thanks.
Old Aug 28, 2015 | 09:08 AM
Professur's Avatar
Sparks are bad, M'kay.
Personally, I would suggest you invest in a Power Probe w/ tracer. And I wouldn't leave the battery hooked up were I you. You're going to have to trace your wires to wherever you've worn through the insulation. Did it blow any fuses?
Old Aug 28, 2015 | 09:13 AM
The ground side of the battery is already connected to ground. Nothing you do on the ground side will affect battery charge at all. Any discharge comes from a short on the HOT side. Find that.
Old Aug 28, 2015 | 02:51 PM
I don't see how touching the antenna lead to the glove box brought on a short as they are both ground.
Old Aug 28, 2015 | 02:54 PM
NJ442's Avatar
It surprised me as well. There was a definite spark and then the fuse blew. Somehow there is current running through the metal parts of the dash.
Old Aug 28, 2015 | 03:44 PM
Both the dash and the outer coax of the antenna lead are ground. More importantly, there isn't any measurable voltage in the antenna lead. I suspect you pinched something else in there, like the glove box light feed wire.
Old Aug 28, 2015 | 06:21 PM
steverw's Avatar
Try getting a test light, hook the ground directly to negative post of the battery then touch the tip to metal under the dash. If it lights up, start pulling fuses and see if one of them makes the light go out. If that works that will tell you which circuit to examine. You will have to extend the wire going to the battery.
Old Aug 28, 2015 | 06:38 PM
Maybe first determine which circuits are on the fuse that blew. One of them is where the issue is.
Old Aug 29, 2015 | 05:52 AM
NJ442's Avatar
The fuse that blew was for the courtesy lights...25 amps. Thanks.
Old Aug 29, 2015 | 06:17 AM
So it wasn't the antenna wire that grounded out, it was the courtesy light feed wire. That makes a lot more sense. Find the bare spot and repair it.
oldspackrat
Jan 1, 2015 06:23 PM
matchek
Apr 5, 2014 02:12 PM
car_designer
Jun 16, 2013 07:19 AM
Redog
Apr 12, 2012 03:03 PM
tim72
Jul 2, 2009 08:23 AM
