battery drain from courtesy lamp circuit
I have a 1968 Cutlass Supreme that seems to have a draw on the battery. By process of elimination, pulling one fuse at a time, the draw goes away when I pull the courtesy/clock fuse ( I checked it with the doors closed). The dome lamp operation seems to work fine. When doors are closed they go off like they are supposed to. The headlight switch seems to turn them on and off as usual. I thought maybe the truck light, but I pulled that bulb and the draw was still there. Anyone have any suggestions as to where else I can look? The car does not have a clock. Stumped!
![Confused](https://classicoldsmobile.com/forums/images/smilies/confused.gif)
I have a 1968 Cutlass Supreme that seems to have a draw on the battery. By process of elimination, pulling one fuse at a time, the draw goes away when I pull the courtesy/clock fuse ( I checked it with the doors closed). The dome lamp operation seems to work fine. When doors are closed they go off like they are supposed to. The headlight switch seems to turn them on and off as usual. I thought maybe the truck light, but I pulled that bulb and the draw was still there. Anyone have any suggestions as to where else I can look? The car does not have a clock. Stumped!![Confused](https://classicoldsmobile.com/forums/images/smilies/confused.gif)
Any aftermarket electronic stuff installed or stuffed under the dash without your knowledge?
Do you have a glove box light? If so is it off?
Do you have an amperage number that you are seeing?
BeenThere
February 6th, 2013 01:13 PM
Cutlass.Don
September 17th, 2010 03:16 PM
