Battery cable issue
Old Aug 10, 2010 | 08:21 PM
bammax's Avatar
Battery cable issue
I'm looking to run new battery cables and need advice before I attempt it.
The last time I put battery cables on an Olds ('74 Omega w/350) the positive cable at the starter kept touching everything in the area and eventually the other end welded itself to the battery terminal. Then the nut came loose at the starter and when I tightened it the solenoid broke into 3 or 4 pieces. The original cable had a small round terminal with a tooth to help keep it aligned and locked into place, whereas the replacement cables that I find just have a 6 foot long metal clamp that touches everything in sight.
If anyone can guide me so that I can figure out how to do this the right way I'd appreciate it. The car I'm working on this time has a 307 incase that makes a difference.
Old Aug 11, 2010 | 05:54 PM
radioburningchrome's Avatar
Everytime I work on battery cables I start with removing the negative cable first. Not trying to be a smartass.
Old Aug 11, 2010 | 06:46 PM
bammax's Avatar
Removing the cables isn't the problem. Try putting in generic autozone battery cables and you'll see exactly what I'm talking about when it comes to clearance at the starter.
I may just start making my own to save the headache.
Old Aug 11, 2010 | 08:27 PM
rocketraider's Avatar
Oldsdruid
If you can't get a genuine Delco Packard cable, I expect CarQuest or NAPA will have a better fitting cable than AutoZone.
Old Aug 11, 2010 | 09:29 PM
bammax's Avatar
After last time I'm sure anyone has a better cable then they do. I'm still thinking of just making my own up once I get my handles on a crimper tool that can handle large guage wiring.
Old Aug 12, 2010 | 02:23 AM
Yellowstatue's Avatar
It's cheaper to buy the cables than buying a good quality crimper...and X2 on disconnecting the battery...
Old Aug 12, 2010 | 02:49 AM
74 Omega's Avatar
I just installed my engine last month, new cables.
I had no issues at all.
I bought a 60" (I think) positive cable from Advanced Auto Parts. It's a 350 in a 74 Omega with headers, it does not hit anything....
Old Aug 12, 2010 | 04:55 PM
greenslade's Avatar
to crimp a end on a cable choose a open wench that will fit snug around the connector where the cable goes in,put wench firmly in a vice with open end up,put cable in connector and put connector in wench,take a punch 1/4 or 3/8 depending on cable size,drive punch into connector between jaws of wench, the wench will stop the connector from flatting out,if you hit it hard enough you may punch a hole in connector which makes it easy to solder connection although I never use solder.put heat shrink on connection.Works great you could proberly tow your car with it.no expensive tools required. Use a punch that is about 1/2 as big as the connector.the wench will proberly be stuck on connector just loosen the vice and tap the wench off.good luck!
Old Aug 13, 2010 | 08:10 PM
bammax's Avatar
That's great advice Green. I wasn't sure where you were going with it when you talked about putting a wrench in a vice, but that's a great idea.
Texas442
Mar 28, 2013 07:13 PM
costpenn
Jan 12, 2013 10:59 AM
w-30dreamin
Jan 9, 2010 03:19 PM
tim72
Jul 2, 2009 08:23 AM
