Automatic radio antenna wiring help
I have an '88 Cutlass and was wondering if anyone had the wiring schematic for the radio antenna. I ripped out a bunch of wiring for the ECU doing my a/c delete and i'm pretty sure the antenna wire was spliced in into one of the wires. It's not too big of an issue, the signal is still fine, I just miss the fancy class of the antenna going up when I start my car.
There's a red wire dangling out of the side which i'm pretty sure is coming from the motor for the antenna. I'm not 100 percent sure..and would appreciate any help you guys can give, thanks!
billleft
January 17th, 2014 05:31 PM
