Autogage Pod Wiring - Background Lights
Hi All,
To aid in monitoring basic engine values, I added a 2-gauge pod from Autogage (water temp/oil pressure) and mounted under the dash. For the background lights on these gauges, is there a specific wire I should be looking for to tap/splice into or is there a spot on the fuse block that I can add a connector to the wires and plug in there? The fuse block is the original fuse block with the cartridge/glass style fuses.
