Autogage Pod Wiring - Background Lights
Old Aug 7, 2017 | 05:48 PM
tgilligan's Avatar
Hi All,
To aid in monitoring basic engine values, I added a 2-gauge pod from Autogage (water temp/oil pressure) and mounted under the dash. For the background lights on these gauges, is there a specific wire I should be looking for to tap/splice into or is there a spot on the fuse block that I can add a connector to the wires and plug in there? The fuse block is the original fuse block with the cartridge/glass style fuses.
Old Aug 7, 2017 | 06:35 PM
4speed455's Avatar
I spliced mine into the dash lights so they would go on and off with the headlight switch. I used the wiring diagram but I can't remember what color that wire was right now.
Old Aug 7, 2017 | 06:38 PM
The dash lights are gray wires.
scrappie
Apr 9, 2013 07:59 AM
tdhill01
Mar 18, 2013 07:09 PM
442Dave
Jan 8, 2012 01:30 PM
Pinner
Apr 1, 2007 11:48 AM
<Rally Pac>
Nov 2, 2003 04:48 AM
