Attacking the wiring options
Old Jul 14, 2018 | 10:40 AM
orangepower1987's Avatar
Hello everyone. I have a 1971 Cutlass S I’m restoring with a 1964 Small Block 330. I’m currently trying to get the engine started and having issues. My car was a field find so needless to say, mice. The engine harness has seen better days. I don’t have as much time to spend going through each individual wire to determine if it works (not sure how I would do that).
My question is this:
Is it worth spending a couple hundred bucks on a new wiring harness, thereby removing a variable of why the engine and other components won’t work? If so, what do you recommend?
Thanks for the help!
Old Jul 14, 2018 | 01:54 PM
Gary's 2 442-S's Avatar
Gary
I believe it is well worth it to replace any harness that you may be having trouble with. Here are two companies I use and both are plug and play and you will be happy using either one.
https://www.americanautowire.com/
http://www.wiringharness.com/
Hope this help you.
Old Jul 14, 2018 | 03:55 PM
Hope this help you.
Thank you so much! Pretty easy to install? Any issues that arose?
Old Jul 15, 2018 | 06:32 AM
RetroRanger's Avatar
72 Olds CS
If your harness is questionable i.e. Cracks in insulation or many splices etc replace it. I have an m and h harness in mine fit good and has the HEI distributor wire instead of a resistance wire.
Old Jul 15, 2018 | 02:14 PM
Gary
They are made just like they came originally from the factory. Very,very easy installation. And no problems after the install.
Old Jul 15, 2018 | 02:54 PM
rktolds's Avatar
Did you pull the whole dash to replace or keep intact?
Old Jul 15, 2018 | 03:32 PM
4speed455's Avatar
X2 on M&H. I had mine built with the HEI wire and set up for internally regulated alternator.
Old Jul 15, 2018 | 08:43 PM
This what I’m leaning towards. Another question if I may, did you replace the dash harness as well? Or did you just stick with the new engine harness? The dash harness is QUITE a bit more expensive and I was hoping to replace engine harness first for $125, get the engine running, and when I tackled the interior I could replace the dash harness if I needed to. Thoughts?
Old Jul 15, 2018 | 09:32 PM
4speed455's Avatar
I did not replace my dash harness. Luckily it was still in good shape. I only replaced everything under the hood, so the engine harness and the forward light harness.
beny0870
Jun 18, 2017 09:32 PM
ankerclanker
Aug 31, 2016 06:48 PM
jason
Apr 5, 2015 07:57 PM
mycut
Aug 25, 2010 07:49 AM
68Tom
Nov 5, 2008 05:30 AM
