anyone know where this connector goes?
Black wire back to firewall, rubber connector, has metal tag connected to wire, tested against + on battery, i show it to go to ground but my reading is 7.7vdc
What year/model is your car? I have seen on the 69 Cutlass cars, and 68 too, with a 350 and 2 bbl carb with factory AC, these cars used an idle solenoid that would bump up the throttle a little when the AC was switched on. This wire could be for a solenoid like that. If your car has factory AC, turn it on and see if you have 12V at this plug.
No, just a single wire and the connector looks just like the one in the photo. The solenoid has a single flat spade on it and it's grounded through the housing which continues the ground through the bracket and the engine. I have a harness set up for this solenoid and a solenoid too. I had installed one on a 442 4 bbl several years back and thought about doing it again on a 69 442 I'm currently restoring. But I decided to keep it original and just used a dashpot instead. The 2 bbl solenoid bracket does not work for 4 bbl applications so I cut it down to make it work. But, it will now just go into the parts bin.
the car is a 69 cutlass S AC350, 4bl,t350,12bolt rear car, I wanted everything original on the car so wanted all wires accounted for
I had a wire mess this one was hooked up to the oil switch but didnt light the light when grounded and doesnt light anything in dash. I grounded the light blue wire and found the oil wire in the alt harness, grounded the green and found temp in the alt harness. but this one was curled up on top of engine by distributor.Long enough to reach front of engine or trans.But im baffled on this on.
I hooked up my meter + to BAtt and - to the connector and i read 7.7 vdc.So it is going to a ground. No change while car is running
I assume you checked this but the rubber connector in your pic also looks like the wire that comes out of the firewall thru a large grommet and feeds to the heater fan blower under the passenger fender.
Or, maybe your car originally had a turbo 400 that also looks like the downshift wire. Or, Maybe all the harnesses had the kick down wire regardless of tranny and it was taped inside if not used?
The wire/plug in question is for the idle stop solenoid. Attached is a photo showing the same wire/plug. The oil pressure sending plug has the terminal offset to one side and the T400 trans kick down wiring connector is much shorter and would not be found on a Cutlass with a T350. Either this car had this installed from the factory and a solenoid was not used, or the car was originally a 2 bbl car that had this solenoid and someone converted it to a 4 bbl and the solenoid was never used again.
thank you all plug identified
thanks 69442C for the excellent picture, Never knew about a idle stop solenoid from the 2 bbl original setup.,,Everyone was so helpful with my wiring issues for the plugs and idiot light this week.
thanks again
thanks again
It's funny to read this thread today as I was just looking at that same wire dangling from my firewall yesterday and wondering what it went to... or more importantly what I forgot to hook it back up to. I have a 69 Cutlass S 350 AC 2barrel carb car that I just rebuilt with a 4 barrel holley. So that would explain where that came from.
Thanks for the great information in this thread!
-Dan
-Dan
dan, if you changed over to 4 barrel carb like i have, then we dont use it, but if you decide to go back to 2 bl carb then you will need. do you still have thbe old carb post a pic, i wouldnt mind seeing the original solenoid setup
ominayak83
April 18th, 2013 10:55 AM
denis
December 22nd, 2006 05:03 AM
oldsowner1977
August 17th, 2006 03:59 PM
