Anyone know of a company that refurbishes fuse blocks?
Old Jun 15, 2010 | 09:10 AM
jugdish's Avatar
The rest of the harness is in great shape. There has to be a way to save it.
Old Jun 15, 2010 | 07:35 PM
fjross's Avatar
Give American Autowire a try. I believe its www.americanautowire.com. I used them to replace my entire wiring harness. The only harness that I didn't replace was the dash harness. The bakeolite housing was cracked around several of the fuses. I sent the dash harness to them and they replaced the entire fuse block as well as the high beam plug. I was happy with all of there repro harnesses as well as the refurbished dash harness.
Dave
Old Jun 15, 2010 | 10:02 PM
jugdish's Avatar
thanks for the info. I'll check into them and see what's available. it would be a waste not be able to use it.
Old Jun 16, 2010 | 03:01 AM
fjross's Avatar
I believe that 99% of the time that they will try to clean up the dash harness unless it's been butchered up. Since the dash harness is not subject to engine heat, outside elements ect..., they will clean, retape and replace what's needed.
Old Jun 16, 2010 | 05:44 AM
If you aren't concerned with "originality" you can always order a wiring harness from Painless. You have to know how to solder though.
Old Jun 16, 2010 | 07:08 AM
ROCKET VAPOR's Avatar
Lance
Try Dave at his e-mail address chevellemania@sbcglobal.net
He goes by "harness tweaker" on eBay, and he does a very great job on restoring old harnesses.
Old Jun 16, 2010 | 10:08 AM
Have you tried a media blaster to clean it up?
Old Jun 18, 2010 | 01:42 AM
Aceshigh's Avatar
Stick with American Autowire for this as well guys. Here's an example of their schematics included. http://www.goindesign.com/typins.pdf
I had a Painless harness put in my 78 Camaro and it wasn't "painless" without any schematics or notes included.
I gutted the Painless out because the install was fubar'd and put in a AAW Highway 22 kit myself ......as a newb and it's awesome.
Every single wire is labeled the ENTIRE RUN of the wire on the sheath.......so troubleshooting in the future is CAKE.
American Autowire is a waaaaay better product and they give you enough schematics to make a newb a master.
Old Jun 18, 2010 | 06:25 AM
I've never used a Painless kit, I just always see it in the car magazines.
Thanks for the heads up.
Old Jun 18, 2010 | 09:58 PM
jugdish's Avatar
Hello,
Thanks for all the input. I called Painless and they said they don't restore fuse blocks. AmericanAuto said they don't do much past 1962 for Olds. The front and back of the fuse block is really bad. All metal is rusted to the point of crumbling. I'm thinking the best option is to get an after market block. There must not be much demand to restore fuse blocks.
Old Jun 19, 2010 | 02:58 PM
Aceshigh's Avatar
If you do not want to rewire the car, and you just want to replace the fuse block,
I'd STRONGLY consider the American Autowire Highway 15 or 22 kit. Unless you want the OEM look of course.
IF you want the OEM look, you'll have to look at their Classic Update kits with the cylinder fuse blocks.
The reason is the fuse block is COMPLETELY separated from the harness by screws.
So you can cut your old one out, and put the new one right in place without removing any circuits.
Here's my 22 circuit block.
Old Jun 19, 2010 | 03:01 PM
Oldsguy's Avatar
Past Administrator
I work with electronics daily and wouldn't mind at all installing something that nice or doing maintenance on it in the future. Nice piece of gear!
Old Jun 20, 2010 | 05:40 AM
442scotty's Avatar
M & H will take your old block and gut it then replace everything when doing a harness...very nice work
Old Jun 20, 2010 | 09:06 PM
jugdish's Avatar
M & H, could you post a web address or phone number?
Old Jun 20, 2010 | 11:54 PM
henryk8398's Avatar
Hangin' out...
http://www.wiringharness.com/
Contact information from the above website.
Sales and Customer Service
(562) 926-9552
Technical Support
(562) 926-9562
24 Hour Fax Line
(562) 926-9572
e-Mail Address
Please do not e-mail us technical related questions. Call our Tech Support line instead.
Mailing Address
M&H Electric Fabricators, Inc.
13537 Alondra Blvd.
Santa Fe Springs, CA 90670
for driving directions check out this map
Old Jun 22, 2010 | 03:29 AM
fjross's Avatar
Unless something has recently changed, American Autowire has dash harnesses listed up to 72 on there web site. It might be worth giving them another call. I delt with Donny who was very helpful.
Oldscutty72
Dec 28, 2015 01:56 PM
siropchik
May 23, 2013 05:42 PM
klovett
Hurst/Olds
15
May 11, 2012 06:43 AM
barry442
Oct 17, 2009 07:42 AM
