anyone have a wiring diagram for a 71 442?
Old Feb 22, 2009 | 02:09 PM
MN71W30's Avatar
I was going to get a manual but figured I'd see what happened here first.
Thanks for any help,
Dave
Old Feb 23, 2009 | 05:03 AM
Lady72nRob71's Avatar
Here is one for a '72. They will be very similar, if not alike.
Hope this helps until you find a service manual...
If you cannot read this one (CO shrunk it down) shoot me an email address and I can send the full sized one.
Old Feb 23, 2009 | 06:21 AM
That's a Cutlass diagram, isn't it? The 442 wiring diagram is a black & white one later in the CSM. The big difference is that the 442 would have had an internal regulator alternator for 1971.
Old Feb 23, 2009 | 09:37 AM
This is a '72, Cutlass, 442, and F85 diagram (A-body). There is no B&W one later in the '72 manual. For '72, the only internal regs I saw was for the Toro.
So watch for these differences between the 71 and 72 diagrams.
Old Feb 23, 2009 | 10:20 AM
MN71W30's Avatar
My fuse box was bad
My fuse box was deteriorated so I ended up with a 72 standard harness and there were several changes from my 71 with guages wiring.The guage plug in plastic pieces were wired different and I had to rewire a few things to still be able to use my outside harness. It took a little time but I got it done. I still need to know where to plug in a few things.
Thanks for the schematic,
Dave
Old Feb 23, 2009 | 10:37 AM
Dave
Even in 72, there were differences between the gauges and idiot light wiring. The two are shown on the right edge of the schematic for 72.
-Rob
Old Jan 15, 2010 | 09:50 AM
clinton70's Avatar
Pro GM
Do you still have a blowup of that wiring diagram and will it work with a 72 Toronado? Thanks.
Old Jan 15, 2010 | 10:09 AM
I have a blowup of the Toro diadram at the house - PM me your emaill address and I will send it to ya!
Old Jan 15, 2010 | 10:13 AM
clinton70's Avatar
Pro GM
PM'd you.
Great car I just got but it's a wiring nightmare. :P
Old Feb 12, 2010 | 12:45 PM
71cutlass455's Avatar
I went to AutoZone.com and made an account there to access their guides. I found a couple diagrams for my 71 Cutlass that came in pretty handy. You could give that a try if you want
Old Feb 12, 2010 | 01:36 PM
Your question is basically the same as the one in this link: https://classicoldsmobile.com/forums...-diagrams.html
Here's the diagram posted there:
If you copy it into "my pictures" on your PC you can resize it or print it
Old Feb 18, 2010 | 02:12 AM
Aceshigh's Avatar
PM'd you.
If worse comes to worst.
There's always an American Autowire kits you can buy and replace it with.
VERY VERY simple to install even for a beginner.
http://www.americanautowire.com/factoryfit.html
Old May 4, 2010 | 08:05 AM
thedodgeguy426's Avatar
Thanks Rob for the diagram copy. It was a lot of help. So I thought I would share my solution. Fuel guage quit working. I thought there was a short causing it to read FULL all the time. Instead, the circuit was not finding a ground. It needs a ground to return the guage to the "E". The sending unit seaks ground through the resister built into sending unit. Pulled the unit, chk'd w/meter-OK. Cleaned the contact rail w/ carb cleaner & a wire brush, removed varnish- Now it works fine. Destroyed the fuel "strainer" but still available through OER. 3/8". Part# K405. Pull strainer off of P/U pipe. Bottom of unit & wrap shield come right off. Thanks Again!!!!
Old May 4, 2010 | 09:26 AM
Originally Posted by thedodgeguy426
Thanks Rob for the diagram copy. It was a lot of help. Thanks Again!!!!
No problem - glad you got it fixed!
Welcome to the site, too - introduce yourself and your car(s) when you get a chance!
Old May 5, 2010 | 09:50 AM
clinton70's Avatar
Pro GM
My fuel gauge is going haywire again. Think my wire patch was too weak.
Old Nov 19, 2010 | 04:57 PM
ramrod's Avatar
I am getting to rewire my 72 cutlass, could you email me a larger pic of the diagram? My email is irdbosn@swbelll.net
Thanks,
Vincenet
Old Sep 3, 2015 | 06:35 PM
bwayco's Avatar
72 A Body wiring harness
Hello,
I got a '72 parts car (350 automatic w/ AC) to finish up my 71 Cutlass S project (455 automatic w/ AC) and ended up using the '72 wiring. The '72 harness is definitely different and is very good except for cutting into the engine wiring harness so an HEI distributor could be used.
The '71 I'm trying to finish does not use an HEI, but does have a Pertronix unit installed inside the distributor.
I was wondering if you could help me out with a picture of the engine compartment wiring diagram w/o rally gauges.
I want to repair the cut wire and connect it properly, but need a diagram to determine where it gets connected.
I appreciate any help you could give.
Thank you for your time!
Brad
Old Sep 3, 2015 | 07:33 PM
Does it have the resistance wire in the harness or has that been removed and replaced?
Old Sep 4, 2015 | 06:39 AM
CRUZN 66's Avatar
Olds Fever
Originally Posted by bwayco
Hello,
Brad
If you are interested, I have both a 71 & 72 Chassis Manual for sale..... $65 each or $110 for both... Plus shipping costs.... PM for more details.....
Old Sep 4, 2015 | 07:27 AM
bwayco's Avatar
Does anyone have 1972 Olds A Body engine wiring harness?
Thanks for the offer CRUZN66, but I was just hoping to get a single picture of the non-rally-pac engine wiring harness so I can put the '72 back to original.
Do you know what wire one would tap into if they were to install an HEI distributor?
Old Sep 4, 2015 | 12:42 PM
RetroRanger's Avatar
72 Olds CS
isnt it posted right up above in this thread ?
Old Sep 5, 2015 | 09:42 AM
bwayco's Avatar
Need 1972 engine compartment wiring diagram.
Sorry for the confusion.
All I want to do is reconnect the wiring back to the stock location after the black wire (which has ''resistance - do no cut' embedded into the wiring insulation) was rerouted to an HEI distributor.
Anyone know where this bulkhead wire goes originally?
Thanks!!
Old Sep 5, 2015 | 12:38 PM
bwayco's Avatar
Resistance wire?
Sorry for not understanding your earlier reply, but, YES, it has the resistance wire ('RESISTANCE DO NOT CUT' on the wire insulation), which is the one that was tapped into.
Knowing that, do you know where I should reconnect?
Thanks!!
Old Sep 5, 2015 | 01:29 PM
svnt442's Avatar
This is from a 70, but the bulk of it should be the same.
Old Aug 21, 2016 | 02:21 PM
Letsrunum's Avatar
I need that picture full size sent to my email address for my 1970 Cutlass Supreme. Inbox me please for email address
Old Aug 23, 2016 | 12:25 PM
svnt442's Avatar
Can you download the picture from my photobucket account?
http://i90.photobucket.com/albums/k2...1.jpg~original
Old Aug 23, 2016 | 02:14 PM
Letsrunum's Avatar
It works but some of the stuff in the top picture is cut off and I need to know what it says because I am having troubles with making my car start from the ignition key. I am getting no power to my fuse but I have it everywhere else in the fuse box. Thought it might be the power coming into the fuse box feeding the fuse for ignition, whether than it being in the mechanical switch. I'm not a pro and I haven't had time to seat down and follow out the wires yet. I am guessing the blue box on top of my steering column is the mechanical switch where I see the red wire going into it and Violet color coming back out to feed the starter?
Old Aug 23, 2016 | 03:12 PM
svnt442's Avatar
OK let me get a better picture of it then because even the one I took with my phone looks just like this one.
Old Aug 23, 2016 | 04:36 PM
Letsrunum's Avatar
That was instrument lights where I thought it said ign..lol. I could check the plug going into the blue box for power coming in on the red wire, then plug it back in and turn the key over to "Run position" so I can check the power coming out on the violet wire of what I think is the mechanical switch(blue box)?
Old Aug 23, 2016 | 07:13 PM
The pink wire off the column connector is for the ignition. Check to see if your bulkhead connectors are tightly secured under the master cylinder. Here is a link to a Chevelle schematic, it should be close.
https://s3.amazonaws.com/ClubExpress...xAGX0Vwapfs%3D
Old Aug 24, 2016 | 12:31 AM
  #31
svnt442's Avatar
I sent him better pics of the Olds schematic.
Old Apr 20, 2025 | 03:29 PM
  #32
rocketolds350's Avatar
are you able to send fullsize wiring diagram having starter issues
RALLYE KID
Apr 14, 2022 06:54 PM
RALLYE KID
Aug 18, 2015 05:48 PM
JBishop
Feb 13, 2012 09:31 AM
'55 88
Oct 30, 2008 02:03 AM
