Does anyone have a wiring diagram for this cluster?
Old Oct 20, 2008 | 06:53 PM
'55 88's Avatar
Question Does anyone have a wiring diagram for this cluster?
I have an extra one of these that I'm going to use in a custom build, and wondered if someone could help take the guess work out of what's hot, ground, etc. I've included a pic. of the back for reference.
P.S. It's a cluster for a 1955 Oldsmobile 88.
Thanks in advance for any help you can provide!!!!!
Old Oct 21, 2008 | 05:42 AM
citcapp's Avatar
You need a motor manual. If your going to re-wire your car. Check out e-bay. Just type in 55 Olds and it will bring up everything they have for you ride. Look for manuals. It will be there. Buy one. And then we can help you. I have a 57 Olds I am fixing up. PM me with any questions you have and I will give you a hand.
Pat
Old Oct 21, 2008 | 03:22 PM
'55 88's Avatar
This isn't going in the Buick it's another car (Model A) that I'm working on.
Old Oct 21, 2008 | 04:51 PM
hialeah56's Avatar
1956 holiday coupe
Ground the frame and apply a positive to each wire then read what it turns on in the front of the cluster
Old Oct 22, 2008 | 04:49 AM
johnfharding's Avatar
WOW this went south for the winter
See you guys next spring!
I think the only thing you would really need worry about is the voltage at the fuel and water temp guages as those wouldn't run off of full 12 V I would think there would be a resistor/rehostat or something that would tame down the 12 v gradually depending on fuel level and temp. Other than that I would suspect the rest of the unit would be lights and full 12v operation. That said get the manual. I got one on order now for 30 dollars off egay I mean bay.
Old Oct 22, 2008 | 04:38 PM
88 coupe's Avatar
Junior Member
Originally Posted by johnfharding
........ voltage at the fuel and water temp gauges as those wouldn't run off of full 12 V ........
They use the same 12 volts as the rest of the electrical system.
........ resistor/rheostat or something ........
That "something" is the sending unit.
Full 12V to either gauge will "peg" the needle at the full/hot position, as it is supposed to do. If it does not, the polarity is reversed.
The ammeter uses does not use 12V as it is wired parallel to the circuit in order to show amperage, instead of voltage.
........ rest of the unit would be lights and full 12v operation ........
Dash lights, yes. 12V power goes into a rheostat, in the light switch. that controls the "brightness" of that system.
Turn signal, and high beam indicator lights, are three circuits, using only 12V.
For more, consult your Factory Service Manual.
Norm
Old Oct 23, 2008 | 04:43 PM
'55 88's Avatar
First, thanks for the information. So your saying that the wrong sending unit will peg the temp. gauge? This is whats happening to mine after the install. How can I confirm I do have the correct sending unit? Also, where's the best place to purchase one, if I don't?
Current wiring: One to 12v source, the other to the sending unit.
Old Oct 26, 2008 | 11:42 PM
88 coupe's Avatar
Junior Member
Originally Posted by '55 88
........ So your saying that the wrong sending unit will peg the temp. gauge? ........
Not what I said.
Originally Posted by 88 coupe
........ Full 12V to either gauge will "peg" the needle at the full/hot position, as it is supposed to do. If it does not, the polarity is reversed ........
Switch the wires on the contacts at the gauge.
........ where's the best place to purchase one ........
Download the PDF Fusick catalog, and check page 41.
Norm
Old Oct 27, 2008 | 09:37 AM
'55 88's Avatar
Norm, Sorry to be a bother, but could you clarify what would cause the needle on the the temp. gauge to slowly peg at start up (and stay there)? What do I need to do to fix it? (Currently it IS getting the full 12V)
Old Oct 29, 2008 | 05:38 PM
Omicron's Avatar
Site Admin & Motorhead
Thread cleaned up. C'mon folks, please play nice.
Old Oct 30, 2008 | 02:03 AM
88 coupe's Avatar
Junior Member
Thanks Paul.
........ what would cause the needle on the the temp. gauge to slowly peg at start up ........
If 12V goes to the + side of the gauge and the - side is grounded, or if 12V goes to the - side, and the + side goes to the sending unit.
........ What do I need to do to fix it? ........
Change the polarity.
........ Switch the wires, on the contacts, at the gauge ........
Or the power and sender connections.
Normally, if 12 volts passes through the circuit, the will needle peg at the top.
Like the rheostat, mentioned above, the sending unit raises and lowers the voltage as the temp rises and falls.
Low voltage = Low meter reading.
High voltage = high meter reading.
Norm
MN71W30
Apr 20, 2025 03:29 PM
costpenn
Aug 29, 2018 11:42 AM
<lkajdf>
Cars Wanted
Jun 29, 2007 02:49 PM
HAFROD
Mar 15, 2007 12:32 AM
