Antennas in 67 and earlier, maybe 68 with no radio
I was wondering, if you did not select a radio option and went with standard equipment (none), I assume they did not put an antenna on the fender?
Maybe this is a two part question.
Are you talking about a special order radio factory delete car.
Are you talking about Oldsmobile putting in a radio in a stripper car.
Ok, that was my question, which, also, was probably unnecessary since power antenna cars, being in the trunk, also got no drilled fender.
It's worth noting that, for these years, the standard was no radio. A radio was an option, thus, the term "radio delete" is incorrect. "No radio option" is more correct.
If I ever were to rebuild a post car 442 into a no-options car, I would need a non-drilled fender.
68RocketAction
December 29th, 2013 09:02 AM
