Another question on my new harness install
Old Jun 26, 2017 | 04:40 PM
vmathy's Avatar
I have a plug on my new harness that I cant figure out. Does anyone know where this plugs in? Comes out of the harness by the distributor with about 2 feet of wire, inside there are 2 green wires and 2 uninsulated wires. I cant find anywhere on the wiring diagram where 2 greens go? Unfortunately my old harness was so hacked up that I cant tell if it ever had this plug.
Old Jun 26, 2017 | 04:53 PM
vmathy's Avatar
Is this the TCS plug? I am running distributor vacuum direct from the carb so I think I can just coil this up and bury it?
Old Jun 26, 2017 | 06:20 PM
70sgeek's Avatar
'72 Cutlass ragtop
it should go to the ported control switch connection and throttle solenoid switch (this is how my original 2bbl setup was wired however I no longer use the TCS tree either, so 1 less connection needed.
Old Jun 27, 2017 | 04:53 PM
Toms cutlass's Avatar
It's the TCS wire. I buried mine when changing the engine harness.
mefirst72
Mar 29, 2016 05:47 AM
Redbud40
Jun 1, 2014 04:36 PM
coldwar
Feb 20, 2014 01:09 AM
ohiocutlassparts
Dec 10, 2013 02:54 PM
we jeep inn
Aug 19, 2010 05:46 AM
