Spent a solid 20 minutes out in the garage trying to track down here and in books what this wire (gray, right in front of 2nd pic) goes to.
best I could find is "maybe" power window relays or something like that, but I'm not sure. For what it's worth, I currently do not have power windows (or locks for that matter) but I also do not have the original interior.
On my 1971 CS convertible the gray wire routes fromthe rear view mirror lamp assembly across the windshield top sill (behind the dress molding), then down the driver's side windshield post into the fuse panel & IIRC I have the same type plug on my gray wire. Do you have a lighted rear view mirror or did the car at one time have a lighted rear view mirror?
Additionally, I believe (look at your wiring diagram) a gray wire feeds your instrument lamps, ash tray & clock lamps. There is one spliced branch point along the gray wire before it runs into the instrument cluster connector. It should be highlighted in the wiring diagram.
I'll double check, but I didn't see anything obvious that looked like it was unplugged. I'm not sure if it did or even does have a lighted mirror. Didn't even know that was a thing.
Also, am I putting too much emphasis on the wire location in the fuse box?
Well, I guess I'm not fully grasping the purpose of the center stack in the fuse box. To me, it seems like an add on.. so my next question is what has been added on. I know its not hurting anything being plugged into the box, but Id like to know why it's there.
I checked the mirror, and on the bottom right there is evidence that something is missing. No switches or anything like that, just a void.
This image (below) is a representative image of a 1968 lighted rear-view mirror. Note the location of the light - which you are most likely missing. Note also the color of the wire and the plug on the wire.
Regarding the center "stack" as you're calling it. I have no clue what that red plug is for - trace it to find out. Do you own a 1968 CSM?
I have a 69 CSM, but was unable to find it (granted, I was looking more for a colored schematic) but I will look into it again. I agree, based on the image versus what I have..it does look the same.
I'd been thinking of getting a new mirror anyway, might as well snag one of those if I have the wiring for it already.
Sorry, I did mean to state a 1969 CSM. I was reviewing some pictures from another thread topic regarding a 1968 442. You can get aftermarket mirrors of decent enough quality. The glass on my original was very weathered and I installed a new lighted mirror on my 1971 CS convertible - works like a charm.
Regarding that fuse box center stack as you called it. I would suspect it's most likely an aftermarket product or some such non-OEM device i.e. stereo/radio, sub-woofer, replacement part, car alarm, whatever. As I said, trace the wire(s). One quick way might be to start the car, turn EVERYTHING on in the car, stereo, lights, etc and then unplug that red plug - I'll bet something turns off.
Well, it's not hooked to anything, but I do have a couple things that don't seem to work.
Im planning on going through the dash next and checking everything to make sure mice didn't get into any wiring. I am going to replace all fuses first off, as well as all bulbs (have already done a preliminary check with turning the key on and noting what did and didn't work)
The only reason this was even brought to my attention is the fact that we were getting up under the dash to pull the booster (Mopars I've worked on are bolted through the FW, opposite of this) so I figured I'd pose the question while it was fresh.
Ah...center stack. Now I'm following (after reading what rocketraider stated)...you mean the center stack as in the moving from bottom to top of the center of the fuse box (like a stack). Didn't think of it that way. Doh me!
Yeah, so as rocket pointed out, that red plug is in the ACC switched position - whatever it's connected to or not connected to.
A cavity labeled BAT is hot all the time.
IGN is hot in ignition switch RUN position.
ACC is hot in ignition switch RUN and ACC positions.
Some older GM fuse boxes have a "LAMPS" cavity tied into the running lights for backup lamps, fog lamps, spotlights etc. Yes, there was a time when backup lamps were an extra-cost option.
A gray wire in the dash area is almost always for dash or accessory lighting on GM vehicles of that era.
I think it's the mirror map lamp lead too. An easy way to tell is pull the driver side interior A-pillar trim off. I'd bet you'd find a gray wire behind there. Tug on it and see if the gray wire at the fuse panel moves. Probably a gray wire peeking out at the inside mirror mount too.
If I remember right the map lamp plugs into an ACC or IGN cavity so it only works with ignition switch. If it were plugged into the BAT cavity it could easily kill a battery.
If yer map lamp is missing, well, you're on yer own finding one without replacing the whole mirror assembly and wire harness!
