Almost final electrical questions (transmission)
Old Jan 21, 2024 | 07:15 PM
rfpowerdude's Avatar
1970 Cutlass S originally 350/TH350, Q-Jet.
Can someone help me with the below? The original trans that came in the car doesn't seem to have any electrical connections, but this is in the wiring diagram in the 1970 CSM for the Abody.
I need to know the answer to the questions in the pic. Thanks!
Old Jan 21, 2024 | 07:31 PM
That pigtail was incorporated into every harness, no matter which trans the car came with. While the TH350 uses a cable kickdown, the original trans for a 1970 will still have an electrical connector, which is used for the high gear pressure switch that triggers the transmission controlled spark system. That pigtail will plug into the trans, though only the green wire is used for the TCS switch.
Old Jan 21, 2024 | 07:35 PM
Thanks Joe, where is that TCS solenoid located? And what does it actually control?
Also, the PO cut any connector that might have been at the end of those two wires. All I did was figure out what they were and now I don't know what to do with them...
Old Jan 21, 2024 | 07:41 PM
I have this shot of the PIM underhood stuff.
Makes it a little more confusing.
Old Jan 21, 2024 | 07:45 PM
TCS is an early emissions control system used on 1970-72 Oldsmobiles that disabled vacuum advance in all but high gear as a way to reduce NOx emissions. The solenoid valve that you see in the diagram simply shuts off vacuum to the distributor unless the trans is in high gear. Most people removed that system.
Old Jan 21, 2024 | 07:53 PM
Aha! Makes sense now. Probably has been long gone. I’ll just insulate and tuck them away.
Thanks!
Old Jan 22, 2024 | 12:50 PM
One last question from earlier. Where is this "trans switch" located? Looks like it is in the interior of the car somewhere evidenced by its location in the wiring diagram.
Old Jan 22, 2024 | 12:52 PM
That is the TH400 kickdown switch on the accelerator. Your car will not have this and the connector will just be hanging from the dash harness.
Old Jan 22, 2024 | 01:50 PM
Thanks a bunch Joe!
Old Jan 23, 2024 | 04:56 PM
Hey Joe, is this the correct connector for the TH400 kickdown switch?
Old Jan 23, 2024 | 05:14 PM
You got it.
Old Jan 23, 2024 | 05:23 PM
Thanks Norm, I was pretty sure it was right since the colors were right, I just wanted to run it by y’all to be doubly sure.😁
Old Jan 23, 2024 | 05:51 PM
I found the exact same unused connector in my 1971 CS convertible 350 cid w/ TH350.
Old Jan 23, 2024 | 06:04 PM
The main reason I’m asking is I am going to use the green striped wire under the hood for power to the HEI by connecting the pink to the orange. The original ignition wire is a resistance wire for the old school coil and points ignition and I don’t want a voltage drop to the HEI due to that wire. And I’m fixing all the hacked up stuff under the hood (and soon, anything under the dash) so everything is dispositioned and fixed and won’t cause any issues in the future.
Old Jan 23, 2024 | 09:52 PM
Yup. That's the one. You can ignore it.
Old Feb 15, 2024 | 07:25 PM
anthonyP's Avatar
4.057 ― SWITCH, TRANSMISSION CONTROL SPARK
1 6462655 1970 ALL TH350
1 6462514 1971-72 TH350
The 6462514 TCS switch has one terminal. From what I could determine, the 6462655 switch has two terminals. Is that correct?
If so, is the 1970 harness connection for the TCS switch different to accommodate the double terminals?
Or is the harness connection the same from 1970 to 1972? With the two terminal receivers set in a T format like in the below photo, one for the TH400 kick down and the other for the TCS?
The top photo is supposedly the replacement for the 1970 TH350 TCS, 6462655. The lower photo is supposedly the replacement for the 1971 & 1972 TH350 TCS, 6462514.
Old Feb 15, 2024 | 07:40 PM
That switch with two terminals really only has a single terminal with two spade terminals on it. The harness has the two terminals in the "T" configuration and won't fit that switch. As usual the Borg Warner catalog is incorrect with respect to Oldsmobile applications. A real factory 6462655 only has one terminal
Old Feb 16, 2024 | 07:50 AM
anthonyP's Avatar
Thanks Joe for the information. I will use the link you provided to order a TCS switch.
Not sure why the parts book has two different part numbers for the 1970 and 1971/1972 model years, or if there is an operational difference in the switch itself.
There was a lone 6462655 TCS switch for sale, but it already sold. No others available. Will need to use an 6461514 TCS switch.
rfpowerdude
May 20, 2023 06:02 PM
Malcolm11
Mar 28, 2020 06:55 PM
Nop
Nov 21, 2016 04:06 AM
agrein8888
Mar 31, 2014 07:53 PM
AZ442
Jul 29, 2009 06:16 PM
